Evan Dutch
Well, bit of a dilemma for me.
I’ve got a 360 magnum in my 71 scamp. Put some Doug’s headers on it recently. The primary tube is way too close to the return hose from my power steering gearbox. So much so that I’ve heat wrapped the return hose and safety wired the wrap in place.
But, as you can see. The header is touching the heatwrap and it isn’t enough to protect the return hose from the heat.
Anyone else have a similar issue? Are there 45 degree or offset fittings I can replace the factory return port fitting with to move the return hose away from the header?
