The TTI 1 5/8"-1 3/4" step headers should be considered similar to 1 3/4" headers. Personally I believe they work even better than straight 1 3/4". They do leave a lot to "grow into". The 1 5/8" just leaving the ports helps maintain velocity and torque while the step up helps overall. I've been 11.14 @ 117+ with a normally aspirated 360, as-cast Indy LA-X heads, .474" hydraulic cam & 10.5 compression at 3,540lbs. It's usually better to be a little conservative, especially if it's a dual-purpose car. But if you build it up enough
all-around, 1 7/8 may help more.
This test is on a mild 300HP 360, but I'm sure that the TTI step difference over straight 1 5/8" or 1 3/4" headers would be even more with a stronger combo.
Dyno chart is shown at the end of the 2nd set of pics in the article.
Exhaust on a Mopar 300hp Crate Engine - Tech Articles - Mopar Muscle Magazine
