swing69
fightin' socialism
SO I watched the videos, did all the prep and marking, got all the materials on hand a prepped. Glass is even removed from the 65 Barracuda. And the famous last words on the instructions were "....with patience, an ammature can be professional results......"
Yeah....right. I can't past the friggin first step!!!!!!!!!!! lol
All my bows are marked correctly, and I marked the center of the fabric, and cut the batten pockets leaving 1" plus of rod out on each side. I installed the back and started to work forward on the 5 bow set up.
Darn it if the isn't an accumulating "error" where the front bow is ~ 3" away from the bow pocket in the side header! wtf? I then started in the middle, and had that bow vertical....moving backwards, the last bow was leaning forward + 1 1/2", and I couldn't pull it enough to install the 2 wires (braces at the top of the back window). And yet the front bow was also "short" by 1 1/2".
There is no way heat and pulling could account for 3" of material. The liner is a REM, so it seems quality.
Can anyone offer any insight?
Anyone want to put in a headliner "IN" in a nice warm shop in NJ.....then the windows???? I'LL pay!!!!!!!
