Heads, what are these ?
Small Block Mopar Engine
  1. MAPS
    MAPS FABO Gold Member FABO Gold Member
    809
    208
    Nov 1, 2015
    Montreal, Canada
    Local Time:
    4:28 AM
    Can someone please tell me what kind of heads are these ?
    3418916G
    These are the numbers on the head.
    Thanks
    • Thanks! Thanks! x 1
    • MOPAROFFICIAL
      MOPAROFFICIAL Well-Known Member
      7,943
      7143
      Jun 1, 2016
      Beach
      Local Time:
      1:28 AM
      Should be a 5 at the end.
      J head, 360
      • Agree Agree x 2
      • MAPS
        809
        208
        Nov 1, 2015
        Montreal, Canada
        Local Time:
        4:28 AM
        Right, it's a 5 at the end.
        So you are telling me these are 360 heads, not 340 ?
        These are the heads that were on Ed Hamburger's car. Strange.
        Then again I think he ran 360s also.
        Thanks.
      • perfacar
        perfacar Well-Known Member
        1,092
        285
        Mar 1, 2006
        renton,wa
        Local Time:
        1:28 AM
        the 71 340 use3d the 915 head with 2.02 valves , 360 used same casting with 1.88 valves.
        • Agree Agree x 2
        • MOPAROFFICIAL
          7,943
          7143
          Jun 1, 2016
          Beach
          Local Time:
          1:28 AM
          They could be 340, if they're 2.02...but 'usually' those heads were -A or -F at the end of the number. I'll also add that they were introduced the same year the 360 came out so production started in '70 I believe for the '71 release of the 360 and of course those castings were machine for 340s too.
          Yours are the ta version , or it looks like ..
        • 66fs
          66fs FABO Gold Member FABO Gold Member
          5,712
          2251
          Sep 9, 2009
          Greenwood, South Carolina
          Local Time:
          4:28 AM
          Possibly 71-72 340. Never took letters into account.
        • Locomotion
          Locomotion Well-Known Member
          3,192
          745
          May 31, 2004
          Florida
          Local Time:
          4:28 AM
          Looks like they were epoxied to port and the pushrod holes relocated for T/A or W-2 rockers. Real T/A heads were 915 also, but there were some 894 castings machined for T/A rockers early on.
          • Agree Agree x 1
          • cudamark
            cudamark FABO Gold Member FABO Gold Member
            8,378
            1126
            Mar 14, 2009
            San Diego
            Local Time:
            1:28 AM
            That casting was used from '70 through '72 on 340 4bbl, 6bbl. and 360 engines. The machining was different depending on actual application. The letter cast into the head after the number indicates early and late castings. A would be first year, G was much later. Not sure the exact breakdown of letter to year/month, but, it gives you an idea. I don't remember seeing a letter higher than a G, so, I would guess it's a late '72 casting.
          • moparmarks
            moparmarks zippindippintie FABO Gold Member
            1,622
            877
            Oct 5, 2014
            Western Colorado
            Local Time:
            2:28 AM
            Actually into 73 on the 360. Probably used up last years stock. My early built 73 W200 360 that my dad bought new has them. 1.88 of course.
            • Agree Agree x 1
            • cudamark
              8,378
              1126
              Mar 14, 2009
              San Diego
              Local Time:
              1:28 AM
              Sure, castings didn't end at a model year or calendar year. There's almost always a spillover.
              • Agree Agree x 1
              • MAPS
                809
                208
                Nov 1, 2015
                Montreal, Canada
                Local Time:
                4:28 AM
                Ok what I know is they have headers that are fitting on to 340 heads so this was one reason they ere thought to be 340.
                @Locomotion
                As for the pushrod work, you are dead on as they are not straight like the stock heads, there was extensive work done on the heads, I would assume by Mr Hamburger himself, as they are similar to the T/A head set up.
                Thanks again guys.
              • Michael Frick
                Michael Frick Member
                19
                16
                Aug 16, 2020
                Erie, PA
                Local Time:
                4:28 AM
                Interesting stuff. When I bought these originally the speed shop owner said they originally went for $3000. But when the W2's came out there wasn't a market for the Hamburger heads. He sold them to me for $1500. Fast forward 35 plus years, kids, houses, etc etc and here they are lol. Going back to a more stock setup for the street and passing on the bracket racing days.
                • Like Like x 1
                • MAPS
                  809
                  208
                  Nov 1, 2015
                  Montreal, Canada
                  Local Time:
                  4:28 AM
                  @Michael Frick
                  Fast fwd another cpl of months and they should be on another 340 and running properly. lol
                  Times are a changing....
                  MAPS
                  • Like Like x 1
                  • dibbons
                    dibbons Well-Known Member
                    4,972
                    2936
                    Nov 6, 2009
                    La Paz, B.C.S., Mexico
                    Local Time:
                    1:28 AM
                    Isn't the other number "03100" a date code of some kind? I don't know for sure.
