1969dodgedart
Big Block 440
Does anyone know if stock blower motor clears 440 performance aluminum valve cover ? I'm assuming not so is there an alternative shallower motor available?
there has been quite many discussions on here and bogblockdart.com. There is a mod. u can do to help. If u have raised port heads u might as well forget it in a 67-8-9 barracuda. I put an underdash hotrod heater in mine just for the defrosters. It has already gone bad., I pulled it out and fixed it but haven`t re installed it yet.Does anyone know if stock blower motor clears 440 performance aluminum valve cover ? I'm assuming not so is there an alternative shallower motor available?
