Heater Hose - Magnum Intake - Help
74desertduster
Tucson AZ
So I bought this Dart Sport with a 360 and Magnum Heads.
I would like to connect the heater but I don't see any place on the intake to run a hose to besides the port that has the temperature sending unit.
Any ideas?
Thanks!
Brian
Is that a bolt head next to the sending unit? It looks like that is where a electrical sending unit would screw in and your mechanical sender is in the
hole for the heater hose. You could do like dgc333 said.
As it turns out the stock temp sending unit will thread into one of those small plugs in the intake. The aftermarket sending unit is too large. So....I took out the aftermarket and used that port for a heater hose and used one of the smaller ones for the stock sending unit with the stock temp gauge. Working good now. Thanks for the help.
