dusdem
Active Member
I press the heater switch on the dash and the blower motor does not come on. When I press the a/c switch the a/c comes on. Are there separate blower motors ?
There is only one blower motor, but when you go into heating, the circuit will go a through a resistor to slow the motor down. You say the A/C works, but does it work on all 3 fan speeds?
What year and model of your car?
Yes, the fan works on all 3 speeds with the a/c. 1974 Plymouth Valiant 318. I can hear something engage when I press the heater. I guess its the vacuum.What year and model of your car?
A push button climate controller after 72 model is greek to me. 73 and up should be the 3 lever controller ( as far as I know ).The only thing I can think is that your electric-vacuum 5-button push-button switch is bad. Replacements cost ~$100. There is a good post w/ photos on opening up one and restoring it. After it melted in my 69 Dart, along w/ the L-M-H blower switch, I added a relay on the blower high position to route that high current around both switches. If not, they all melt eventually and these parts are getting scarce. At that time (~1990), a new switch was ~$20.
