HEI 4pin module connectors?
Gimike812
Tucson AZ
Let’s start with this is not my first HEI swap I have done 2 others successfully on slant six cars. I have searched a few hours a couple days now and don’t think I am finding the correct part I am looking for if it even exists.
I am looking for female plugs(sockets, connectors) for both sides of the 4 Pin HEI module. Yes I know you can use spade connectors I am wanting a cleaner looking install. And no I don’t want to hide the module underneath the distributor or to run an all in one distributor because of the limited space in an early Abody.
Buy a used HEI distributor or call Summit tech support. They have the plugs you are looking for. I used the same heat sink and mounted it under my coil to hide the module. I painted a MSD coil for HEI flat black so it looks like a factory coil.
Syleng1
On the one side that goes to the coil I used a Napa GM alternator plug. The other end that goes to the magnetic pickup I just cut a plug out of an old HEI distributor
