TylerW
Guys:
I built one of my HEI conversions for the Dart, using a factory GM coil, module and the factory Mopar distributor.
Having a strange problem: The engine will not fire when the key is in START position. As soon as you let off, it runs for a second or two, then quits.
There is nothing going through the ballast resistor anymore, so that is NOT the issue. These run off 12v directly to them.
I did double check to make sure the voltage was there during crank and it is.
Any thoughts are welcome.
