Joshua Suehs
Hey all! So I bought a HEI Dist. and the blade at the end of the dissy seems longer than my original. It is making thr base not seat by about an 8th of an inch. Has anyone had this issue? Can I just use a grinder and grind it down to the old length? If I leave it will it still work or will it be putting unnecessary pressure on my engine?
The second question I have is when bypassing the ballast and ECU. what wires should I solder and what can I leave/get rid of. I have seen many posts on this but a lot of different things for the 73 dart swinger.
I would love to hear what you guys have done and any feedback on the dissy. I don’t think grinding would hurt but wanted input. Thanks!
I’ll add pictures when I get a chance!
