Help 64 Dart
fordilac
okiedart
lake ozark mo
I am rebuilding the front end & the bushings on the lower control arms where the torsion bars meet are wasted. What is the trick are these pressed togetheris it threaded I have the arm off the car next where can I get the bushing the auto parts doesnt show it
There are alot of threads here on FABO to research replacing the lower bushings. Yes, they are a press fit and a PITA.
Moog Part #K791 You will need 2 kits if you're doing both sides
