Help, 65 barracuda 73 engine
no1newb
Speedway, IN
i just bought a 65 barracuda that has a 73 barracuda engine in it, it was originally a automatic, but at some point some one changed it to a 4 speed manual. the guy kept it in real nice condition, just bits in pieces need to be fixed.
while it is still drivable, but still has some parts moved out for easy assess for other things, is there a easy way to put a tachometer on it, i am just now starting to learn about cars, but i understand how things work, just not the specifics.
thanks in advance.
You can put an aftermarket tach on it...directions will come with the tach.
Green wire to negative side of the coil,black wire to body ground,red wire to ignition,white wire to fuse for instrument lamps :cheers:
