Ok I picked up a 79 OD trans to put in my 64 Valiant. I finally got it all installed drove it once and had a lot of problems getting it to shift in to first and reverse, not bad enough that I could not deal with for short drives. So I did some research and found that the shifter adapter might not be the correct one. Then the side cover sprung a leak, so I got a adapter from a 64/65 cuda. Then I pulled the trans and using a factory service manual took the side cover off, put a new gasket on and like to never get the side cover back on. I did get back on and I checked to make sure that it shifted smoothly and it did. So back into the car the trans went, after some bending of the shifter linkage rods it was all hooked up. Filled the trans with 30 weight, started the car and now the I cannot get the trans into first. It goes into reverse, third and fourth. Third and Fouth is easy to get into, reverse requires some effort. Now when I get under the car and have someone try to shift it into first, it looks like it is also trying to put the trans into reverse. When the shifter moves the linkage rod to go into first the reverse rod also engages and it looks like it is shifting into first and reverse. Now when the car is running and you put it into what is suppose to be first the car bogs and stalls, like when you would try to take off in fourth gear. I am completely confused, is it the trans, is it the shifter, is it the linkage, or is it the adapter .............I have been screwing around with this all week and I am ready to strangle someone over this...
Please any sugestion
