SOUPENE
ok here's what iv'e done
iv'e checked the flasher modules they both work when you put the emergancy flashers on but when you try the turn signal nothing next i checked the fuse box all the fuses look good all the bulbs are fine i tried to check the switch but you cant really get into that plastic housing to get a good look i thought it might be the switch because i got a lil overspray on it when i painted the colom but i dont know im at my wits end :spiderma: is there any thing im over lookin? any ideas ? like i said when you pull the emergancy flasher switch out all the correct lights flash so what am i missing? "help"
thanks
Dan
thanks
Dan
