Oil cap on the drivers side, pcv on the pass. side. The big bracket was on the pass. cover and wasn't used for a heater hose but for the vacuum advance hose and wiring. That area is quite close to the heat riser passage and gets damn hot... Yes, in 67 they changed from the stove pipe pcv to a grommet with a push in valve. The plug wire looms came around in 67. The 65-6 plug wire holders were the white colored individual ones. tmm
