help identify this cam
Probably a old TRW/Speed Pro grind. Would need a old catalog, for specs.
It's a link with the TP216 cam specs. Looks like it's a solid roller for a big block.
Its my sons got it for free and litters etc going in the mud bogger tomorrow
Haha 13.5:1 383 big bore short stroke should rip we were gonna use the 426mw but don't wanna bust it
Part number is TP216 (Sealed Power), CS1123R Speed Pro. Comp Cams grind number is CRB-3 306B-R8
Specs:
Part number: 23-758-9
duration @ .050" 275/275
lobe lift .4167"/.4167"
lobe separation 108
gross lift .625"/.625"
valve timing at .020"
Int OPEN 43 BTDC CLOSE 83 ABDC
Exh OPEN 79 BBDC CLOSE 47 ATDC
valve spring recommended Comp Cams 938
So its only 416 lift?
Specs:
lobe separation 108
There are two ways to list the lift of a cam. Lobe lift and Valve lift (gross lift).
The lobe lift is how much lift the lobe of the cam has. Take that and multiply it by your rocker arm ratio to get the valve lift.
So in this case, you take the .4167" and multiply it by the stock rocker arm ratio of 1.5:
.4167 * 1.5 = .62505" or .625" lift at the valve.
If you used a 1.7 rocker arm ratio it would be:
.4167 * 1.7 = .708"
