help me choose my piston
does anyone know anything about these pistons?
Wiseco makes darn good pistons. Only 2 things you have to watch out for is getting the right rings. They take 1/16 compression rings which are a standard high perf. ring but the stock 360 rings are 5/64 so if you order a kit make sure and get the right rings. And they don't have valve reliefs cut in them. You have to either make sure and not go too big on the cam or the valves will hit the pistons.
Looks like compression ratio is right where you wanted it too. That's good.
