parrainx
Member
My '65 Valiant was missing speedometer cable and shift cable. Looking at the repair manual both of the cables have push in type connections at the tranny, but mine has a screw in speedo and a lever for a shifter.
From what i learned searching around i might have a 727 (I thought it was only V8s), rather than 904 trans? Starter is on the top. Also the driveshaft slips onto the spline (if that's any indication). I included some photos.
I already got the speedo cable, but need help finding the shift cable (column shifter) any idea where i can get OEM style or aftermarket one that will work.
Thank you.
Thank you.
