69cudanutz
Active Member
am having a light wiring d'lahma- am trying to get run and brake lights back into what was a previously good working car -- body man took out the dash cluster 4 paint -- if i join / short the ammeter wires the car will start and run even when ammeter wires are disconnected from each other ,, i have power to the fuse box with all fuses good-both sides - when they are hooked together but no brake or run lites - no signal lights is understandable with dash cluster out - - cluster is completely out with switches / wiring left untouched other than being disconnected from the cluster - ground wire on the rad support is connected - is it something simple as missing a ground somewhere off the dash ??- or - do ALL the run lamps sockets front and back need B hooked up with/ or without the dash installed - one suggestion here was-- the lighting system only works IF everything is wired / installed up front and back - any help / suggestions out there to get some running / brake lights to drive without the cluster installed ?? could really use some good helpfull suggestions here and wood be appreciated -- thanks cudanutz
