I'll chime in now...
I run a 73 vintage 318 (rebuilt .030 over and has 30K miles since)in my Duster. Currently, it has stock heads, with a 7 angle valve job, Performer intake, Edelbrock 1405 600 cfm carb, Hooker headers, Comp XE268 cam (same cam), MP quick advance distributor. Pistons are 8.5:1 Speed Pro cast units.
I am running a 904 with TF-2 kit and a custom built 2800 stall converter.
With 18 degrees of initial timing and 36 total, it runs 14.0-14.5 in the quarter consitantly, using 3.23 gears and 235/70/15 (28" tall) rear tires. With more gear, I am sure I can knock a half second off. It will light the tires at will from a stand still, but cruises around town well and turns about 3000 rpm at 72 mph.
That being said, with the 302 heads, your compression is going to be higher. I would aim towards a custom built converter in the 2,800-3,200 range and leave it be. If you were to change manifolds to anything else, I would search for an LD4B or LD 340. The LD4B will have 318 sized ports and is a very good piece.
-Justin
