ramcharger
Dismember
What truly concerns me is the combination of wiring harnesses, both used and new.
Seems like this is the problem...... Components are good, but there is a wiring issue in the harness somewhere that is confusing to say the least, but we got some super help today from a member here:
http://www.forabodiesonly.com/mopar/showthread.php?t=51095
are you using a factory electronic set up and wiring .. or a mopar performance add on kit ?? if you want to convert to the moper formance add on,,im sure some oen has a diagram of how to wire it,,,maybe thats where the problem is,,,
i probably missed it but did you replace the coil?
10+ volts at the +side of the coil during crank and run means you wiring is ok.
You are using the MP balasist resistor (2 prong, not the 4 prong), right?
Air Gap set to .008"?
if yes to all, it will fire. if not, the problem is in one of the three things i mentioned.
now i'm off to rip around in my suzuki dr350.. in -30, & 2ft of snow.
cheers.
Interesting... You need the voltage readings as mentionned. Sounds like either a bad pickup, bad pickup wiring, or low voltage on "start" and "run".
Is the 5 pin harness for a 4 pole resistor? I have the 5 pin harness on my 68 but I`m only using 4 wires. This is with a 2 pole resistor though.
Good job charger70! Glad you could be there to help.
AAAARRRRRRGGGGGGHHHHHH!!!!!!!!!
I HATE ELECTRICAL PROBLEMS!!!!
Come on, Everybody say it with me!!
Good Job everyone,
Now I feel like we are in this together.
Thanks.
quote]
Really loud.......I HATE ELECTRICAL PROBLEMS
Here is a pic of the actual ECU plug in received on the Evans harness............
Wow, good catch guys, you realize of course that now you're the resident experts on this site and that "all" electrical questions or problems will be your responsibility to solve. :toothy10::toothy10::toothy10: Congradulations!!!!!!!!!!!!!!!
Terry
