h4e2m6idavid
72 demon 340
Ok I put inner & outer tie rods bigger style c body also used new sleeves also put on bilstein shocks. Ball joints look great regreassed and also put on a new pitnam arm. All done car steers terrible and makes a horrible 'squell' noise worse as you go faster just did the around the block. I followed the original tie rod thread outs so I thought I had it close but seems that the toe is way off I don't even want to drive it anywhere with this crazy noise ! I checked for any clearance issues no rubbing anywhere please advise on your mopar thoughts thanks Dave
