71 Valiant Plain Jane Cluster
Got the car a few weeks ago, runs and drives great....
Fuel gauge works from 3/4 full to 1/4 empty consistently. All other lights/gauges works except for the temp. gauge, I've seen it move once from dead to close to "cold" position.
There is no rust on this car, everything is as close to perfect as you would ever find in a survivor more or less.
I poked the sending unit wire with a multimeter, got nothing... tried grounding it, no movement, nothing... tried testing at the firewall bulkhead, the pin beside the purple/violet (temp sensor) wire has a full 12 volts, but nothing from the temp pin.
Everything I've read indicates that they usually fail together due to the regulator but rarely does the fuel keep somewhat working and the temp doesn't?
