I very carefully on a bench removed my standard printed circuit dash. I took the round harness plug that feeds all the instruments and cut the plug away from the wires. I installed all new autometer gauges in a new panel. I then used my manual to follow the color code wires. I added more length to each wire using the same color wire so I would not get confused. I very carefully installed spade plugs on each wire and clipped them on to each of the corresponding gaugues. My question is when I check my fuse block and the schematic, the last fuse I have has a double orange wire and a beige wire. when I probe the fuse I have no power at the fuse? I changed the fuse 20amp and still have no power with the switch off or on. My other fuses all have power some constant and some only when the ignition switch is in the on position. But I don't seem to have power on that one fuse with the orange wires? Is there something I am missing when converting the printed circuit dash to individual gauges. I basically took that orange wire and ran it to each guage and then jumped to the next guage on the positive terminals. I have attached a few photos of what I did. But I have no power at that fuse with the orange wires and the tan wire? I should also say that I also eliminated the amp guage for a voltmeter. I removed the amp guage and soldered and tied the large red and black wires together. I ran a new wire directly from the alternator to the battery. I don't know if that interrupted anything??
