davezinn
Active Member
i'm planning on buying a set of Cragar S/S rims for my '71 Dart. it already has the 4 1/2" bolt pattern on it with front disc's from a '74 and the rear axle as well. i want to run the 15x4's on the front and 15x7's on the rear. will the standard offset 15x7's fit the back with a G60-15 tire? i'm planning on running Mickey Thompson Indy Profile S/S's in the back in the G60-15 size. the car will sit at slightly higher than stock in the rear. my current rear wheels are American Racing Outlaws, 15x8 with 255/60-15 BFGoodrich Radial T/A's. they fit perfect with no rubbing issues at all.
