nm9stheham
Just know that if the cylinders are all within a .005-.006"" deck height range, the total static CR variation cylinder-to-cylinder will be around 0.1 point based on that factor alone. If the head chambers are equalized to get rid of that variation, then that is a pretty good CR variation to live with for a street build; IMHO, you don't have to go crazy with this parameter for most uses, you just need to know it is not way out. There's going to be some other cylinder-to-cylinder variations that you can't do much about, like intake and exhaust port variations and such.
