Help With Fender Tag Decoding
Wyolemontwist
Member
Cheyenne, WY
I am looking at purchasing a 1969 Plymouth GTX and I am having trouble decoding the fender tag. There is a sideways G on the right side of the tag and the VIN is split between the bottom left corner and the top right. The VIN on this car is: RS23L9A458023. Any help decoding this tag would be greatly appreciated.
OK, heres what I can tell you about this fender tag. The bottom row...RS23= R=Belvedere/Satellite...S= Special...23=2 dr. hardtop...E86= 440/1 4bbl (375hp)...D21= 4 spd trans...012667= Vehicle order number. Second line... F8=Ivy Green Metallic paint...F8= Roof color (same)...P6F= P=Premium...6= Vinyl Buckets...F= White and Green (2nd color is carpet, insturment panel, steering wheel and headliner)...F8= Upper door jamb color. 3rd row...not sure about the 68. 4th row 26= 26"radiator. 5th row...915=engine code 440/1 4bbl carb (375hpw/ 915 heads)... 596= axle code (3.54 SGw/ 9 3/4" Dana)...605= trans code ( A833 4 spd 440/426 engine) 6th row...production order numbers except the last sequence which is your last half of the VIN...9= 1969... A= Lynch Rd. plant... 458023= buils sequence.
This being a Lynch Rd. built car, it has a unique and very difficult to decipher fender tag which will show almost no options the car came with. These will have to be gotten from the build sheet. What you have here is a 1969 GTX, green outside with white buckets and green interior, 440 with a "hemi" 4 spd trans and Dana 3.54 Suregrip. Not a bad car. Hope this helps, Geof
I don't think the 915 code means it has 915 casting heads. I believe they were only used in 1967.
No 915 heads in 69... they were all 906 heads at that time.
the "68" is a delete code for the rocker stripe.
Here are the engine, rear, trans codes for the 915 596 605 numbers
Engine
897 - 383 4BBL, manual transmission, A/C, 330hp, Turquoise
899 - 383 4BBL, automatic transmission, A/C, 330hp, Turquoise
900 - 383 4BBL, automatic transmission, heater, 330hp, Turquoise
915 - 440 4BBL, manual transmission, heater, 375hp, Orange
916 - 440 4BBL, automatic transmission, A/C, 375hp, Orange
917 - 440 4BBL, automatic transmission, heater, 375hp, Orange
921 - 426 Hemi, manual transmission, heater, 425hp, Orange
922 - 426 Hemi, automatic transmission, heater, 425hp, Orange
925 - 383 4BBL, manual transmission, heater, 335hp, Orange
926 - 383 4BBL, automatic transmission, heater, 335hp, Orange
Rear Axle
589 - 3.23 open, 8 3/4, 10" rear drums - front disc
591 - 3.55 s/g, 8 3/4, 10" rear drums - front disc (A36 Pkg)
592 - 3.23 s/g, 8 3/4, 10" rear drums - front disc
593 - 3.23 open, 8 3/4, 11" rear & front drums
594 - 3.55 s/g, 8 3/4, 11" rear & front drums (A36 Pkg)
595 - 3.23 s/g, 8 3/4, 11" rear & front drums
596 - 3.54 s/g, Dana 60, 11" rear & front drums (A33 Pkg)
597 - 3.54 s/g, Dana 60, 10" rear drums - front disc (A33 Pkg)
642 - 3.91 s/g, 8 3/4, 10" rear drums - front disc (A31 Pkg)
643 - 3.91 s/g, 8 3/4, 11" rear & front drums (A31 Pkg)
644 - 4.10 s/g, Dana 60, 10" rear drums - front disc (A32/A34 Pkg)
999 - 4.10 s/g, Dana 60, 11" rear & front drums (A12 Pkg)
Transmission
091 - 727 Automatic Transmission, 383-4BBL engine
093 - 727 Automatic Transmission, 383-4BBL & 440 HP engines
094 - 727 Automatic Transmission, 426 Hemi engine
603 - 833 4-speed Manual, 383-4BBL engine, (23 spline)
605 - 833 4-speed Manual, 426 Hemi & 440 HP engines, (18 spline)
Yep, my bad guys!!! 915 isn't a 67 code!!! It was late, and after band practice and, and...well I goofed!!! That damn Lynch Rd. tag is hard to read through!!! Geof
I know, I don't like those tags either. What the heck where they thinking when they decided not to use the same codes as the other plants!
I had to read through the book on how to read that damn tag!!! I think I got most of it right though...now if I could just do that with the 68 and earlier tags!!!UGGGHHH!!! Geof
I have most of the codes for the '66-8 models. Let me know if you need help on one.
Mark
Engine
Rear Axle
Transmission
Where can I find a list of these codes and the codes on line 3 of a lynch road fender tag? Are they in a book I can buy?
Not much info about Lynch road codes.
What year, make and model?
And do you have any of the Galen Govier books?
Ha!
There are no 'experts'.
We all have way too much to learn yet. ;-)
Lynch Road tags are off by themselves, each plant manager had leeway to code certain things the way they wanted too.
In this VIN range, some errors were made, the VIN is a typo & it is not the only one. The first 4 in the last six should have been a 1 & the SPD is a typo also.
Other examples are known.
Possibly a new employee at the tag machine or? We may never know for sure.
