Help with jet size please
troubles brewing
grande prairie,alberta
Heres the combo.
0.O30 over 440
1050 quick fuel 92 jets
440 victor manifold port matched
victor regular port heads ported
11.3-1 flat tops zero deck height
6 pack rods
factory steel crank
msd distributor
727 tranny brake
4:30 8.75 rear
29.5-11.5-15s
shift at 6000,through the traps at 6300
94 octane+octane boost
2200 ft elevation
The carb came with the 92s.Any suggestions on were to start.
Did a best time of 11.02-121mph with carb not at full throttle.
Had the cable set to long.
Thanks for the help; Rick.
The best way to jet is at the track make passes and add jet till your mph drops off then go back to the best mph! Squirter size gives you your 60'! Add squirter till it blows black out the back then go down two sizes. That has worked for me in the past.
