Hello! Im one of those guys who really likes the 318, 400 crank with only a cam, intake, carb and flat tops that actually reach within 20 thou of the quench pad in 302 heads is the street build I had a while back in my 61 lancer. I want to go farther though and want some tips as I have a better skill set now, and a better understanding of how these engines make power but I’m no genius.
Now I’m not some top of the line engine builder, I’ve rebuild engines back to stock but customizing them? Never anything internal.
i have two plans (and don’t tell me to get another motor, I want to use the 318). Both use the 318, I’m capable of building these engines, I want static compression to be no less than 10.5 to 1 and no higher than 11.5-12 to 1.
If you know exactly what parts will give me that compression ratio please tell me, or what parts may put me in the ball park!
Plan 1: stroker kit to a 390 (4.0” stroke) and some 302 close chamber heads or depending on compression numbers maybe X or J heads with the bigger valves for the longer stroke. My questions here are, what would street drivability be like here? What compression ratios can I expect between the 302’s and the open chamber larger valve heads? The 302 valves definitely aren’t a bottle neck of any sort.
Plan 2: Kb pistons makes the 167 flat top which seems to be the closest to 0 deck I can find in my experience having rebuilt a few before with mold upgrades, these with the 302’s seem like they’d hopefully produce the numbers I’m looking for (450 crank because I had that number from a customers engine who supplied all the parts, I believ the aluminum heads they had made the biggest diff)
Plan 2B: kb399 domed pistons but I have a problem with these. If they don’t fit the closed chamber heads I’d rather switch to flat tops than switch to a more open head. The 399 if I ground down the spark plug area like some 340 and 360 aftermarket domed pieces I bet it will fit. That’s if they hit at all and I understand this combo will not be okay with pump gas (most likely, if the 302’s fit I can use the quench pad to help detonation but still)
I want to know if anyone’s ever ran 399’s on the heads I mentioned or ran 399’s at all. What did you think? How was clearance?
And do you think I’ll get higher compression using open heads and domed pistons or 0 deck flat tops with closed chamber 302s?
As I said before, the 318 is a must. I’m open to open chamber heads if someone explains why it’d make good power.
The few things I do know:
At work the guy who does the headwork and has build many a small block mopar says the stock valves are fine to 5500rpm but the ports are restrictive, now I know how to port so I’ll be doing that.
I don’t want to notch the bores in the block. Also what’re your 318 power build numbers? At the shop our most powerful was 590 crank NA with a 318, cam pistons heads sprints intake carb headers yada yada. My goal is 475 crank, hopefully a little under 400 at the wheels if not 400 mentioned in the beginning I have pieves together multiple 318’s with those numbers but I didn’t pick the parts I just assembled them. Anything ultra high performance I still need more certs and experience first.
TLDR: what combo workk get me minimum 450 crank on a 318, stroker? Flat tops and closed chamber or domes and open chamber?
!!!!This is for a dodge aspen R/T with original stripes and blacked out chrome, factory lip spoiler and all the louvres!!!
Found a burgundy interior for it as well out of a junk 2 door because the rt has nothing good inside besides the dasg
