Lil Scamp
Member
We just installed an aftermarket instrument cluster and gauges on my dad's 71 duster. I advised him to also re-route the alternator wire bypassing the bulkhead connector as he now has a volt gauge instead of the amp gauge so we did. The car has always had a bad light flicker and you can really notice it now with the new volt gauge bouncing from 14v-16v. After lots of searching I see its not uncommon when a MSD 6AL is installed (which has been on there since the car was built). I found a thread on another forum which was successful after a diode was installed from the ignition wire from the MSD box. I tore apart an old radio and found a diode and spliced it inline with the wire, no change. The weird thing is, if you take the ignition wire feeding the voltage regulator off and hook it directly to the battery, the flickering stops and it charges perfect. Has anybody had this problem and had success fixing it?
Here is the successful thread: Ammeter/Main Voltage Fluctuating | Moparts Question and Answer | Moparts Forums
