Hemi 90 degree oil filter adapter
Ozyduster
Australia
Anyone running the 90 degree oil filter adapter with the hemi. Does the adapter and filter clear the K frame etc?
If so does it have much clearance as i need 10mm to the k frame for engineering reasons. The 90 degree adapters are not cheap however i want to avoid a oil filter relocate kit as think they are messy
It should as the holley only brings motor forward i would think its the same height
Do you know what size and how long the mounting bolts for the adapter are? Mine didn't come with any bolts or the oil filter threaded adapter
I have not purchased one yet as wanted to know it works lol as they are not cheap but dont like the oil filter relocate idea
Oh sorry I thought you bought one already. I found one about $100 cheaper than going through Bouchillon performance . But mine didn't come with the mounting bolts or the oil filter threaded adapter.
the only thing that might give you fits is the sensor on the back of the unit. might have to plug and move to a different location.
Anyone used the bouchillion unit as looks to have a smaller 90 degree bend and a longer arm so pushes filter further away from k frame. Not cheap tho
They (Mopar) do supply a minature oil filter i have been running 1 for 1,000 km without any problems
so i bought some stuff to see if i can make work. bought one of these ford 90 degree mounts. the mount screwed right into the block but its soo tight that you kinda have to angle it weird. unfortunately i forgot to take pics of it mounted when i still had the engine in there but the filter will come out behind the alternator in between the k member area. ill need to trim the motor mount (i have a 6 banger k member). also need to figure out what filter would fit.
