hemi swap
salynn
florida
hemi swap, Im going to do the same thing but Ill use a291 55 Desoto hemi. Ive got every thing except the oil pan and oil pump hitting the center steering link, did you just tunnel the pan and rework sump pick up tube or is there a shallower pump an reworked pan on the market , take any input. thanks
You cannot just put rack and pinion in these cars, or "everybody would be" doing it. You either need an aftermarket suspension such as Hemi Denny, Alter K or similar, or "re-engineer" the front end yourself.
