HHR fans
dartcuda1
67 Barracuda 500ci 6sp
Malvern Pa
Can one tell me about the HHR fans.how good are they and how to hook one up.Thanks for any help. Mark
We bought one off rockauto.com and put it on my son's '88 Mustang with turbocoupe engine. Quiet and works well. We run a fan relay from summit racing. Also, rockauto has the wire connector to that plugs into the fan. We had to fab up some brackets and use some foam to seal the sides to the radiator. We cut the ears off with a jig saw and sealed up some of the holes in the shroud with black gasket sealer. You do a google search on HHR fans you will see lots of info out there.
