[WANTED] Hi all, I am in need of a small block cam and lifter set.
CUDACOX
Innisfil, Ontario, Canada
Here's another throw it out there request... If anyone is going to Carlise in a couple of weeks, and has a small block cam and lifter set for sale I'm interested.
I am looking for a 484/284 or very close, I don't care if it's older as long as it's never been used.. Thank you in advance! Craig.
Hi,
I have a couple options for cams and lifters. The Mopar cams are advertised duration and are about 241 degrees at 0.050 lift.
- a used solid lifter Mopar 528/284 with 112 degree LSA with matching lifter set. Bracket racing for a couple summers. Great shape.
- a new solid lifter Mopar 526/284 with 108 degrees LSA with new set. Has a few minor pits on one journal. Lobes are perfect.
- I also have a custom ground solid lifter cam and matching lifters with, by memory, 519/526 lift and 240/244 duration at 0.050 lift which is within a few degrees of the two Mopar cams above.
Thanks
Hi,
Thanks
I hope it’s ok with the OP since he is looking for a hydraulic cam, but I sent you a message about those cams you have. I’m looking for a .528 for my 360.
I've got a Mopar Performance P4452782 cam and lifter kit.
and a Comp Cams CL20-223-3 cam and lifter kit.
If interested.
If interested.
An OEM 340-4bbl cam, nice. A bit smaller than the requested size, but really nice for a resto project.
That comp has what I’d say, IMO of course, probably the best street muscle cam type of specs for a nice power increase and drivability. I have the roller version with 1.6 rockers.
Jumping in on the OP’s request for this stuff?
Pretty slimy of you
