Hi! stripe question
Numbers people can be dicks ,true
....they take so much pride in knowing, I guess...idrc. just dont get you're dick in a knot over it. Make a phone call 1st, that sheds you of the **** stirring title from the start. But who cares, these threads are entertainment, at the least.
I am far from a numbers guy. And I thought I was contacting them in private when clicking on their name.
I just like seeing stripes the way they were . You want to add your own stripes from a Camaro fine. If that is your thing go for it. But don't sell someone a stripe kit that is that far off from OEM and state it is. Some guys don't know due to they never owned one with factory stripes.
I am a critic when it comes to sellers misrepresenting parts . They should state .There not perfect but close and show actual pictures of their product. Do you actually believe that all of these venders have a car for all of their stripes to show what you are actually buying? No they use pictures off the web. I really don't have time for the degrading comments anymore. If your happy with the stripes you see on the brown car then buy them. I thought someone should point this out to the Vendor that was mentioned as the seller in this thread. [FOR SALE] - 1971 Duster 340 How would you like too apply these to your freshly painted Duster. They are not applied wrong. The car isn't 2 inches wider with bondo. They are just a real screwed up stripe kit.
I put these stripes on this gold Demon and others 30 years ago they were OEM the fuel cut out was in the stripe. There was no way possible to apply them to the wrong side up side down. The taper and arc are different from side to side. And the factory cap is painted on stripe color. I have not seen one kit today that is cut correct where the handle is painted stripe color so it matches the height of the stripe. But some of you nice guys will argue to no end because yours are wrong and you will never accept that. I am not trying to degrade your cars just making you aware that they are not correct.
I don't care I just like making people aware . I put so many of these stripes on at the body shop back then I notice everything wrong with these repo stripes. I added some pics of OEM stripes on demons. I have not found a Vendor that makes the correct stripe with the cut out in the stripe designating left side. When I received my duster Stripes for my orange Duster I took them to Jet signs along with old twister stripes I had . He trimmed the repos to match the OEM's The quarters were pretty far off.
Steve, this just might all go away if you would quit baiting people by calling them assholes. And to even suggest that someone put Camaro stripes on their car isn't helping a bit! I've followed you a bit on here, and I don't think you're a bad guy, but I suggest you take the high road and stop insulting everyone that suggests you may be wrong about these stripes.
It never goes away. I'm use to it.
Alot of times,all the stripe maker had to go off were tracings of originals so the dimensions were close enough, but not precise.Sometimes,they even had to go with a "best guess" from pictures.Advertising them as Mopar authorized restoration products gives an impression that the stripes will be identical to the factory originals,and in some cases,they are not.
Another of their stripes that's "off" is the tail panel for 75 duster 360.They did not have an original stripe to go off of so did the best they could from pictures.I have an original set and tried to get them to reproduce them but they didn't have proper equipment at the time to do the job.They ended up damaging one of my originals while in their possession and just shrugged their shoulders and left it at that.
I guess a close stripe is better than nothing...?
Here is another comparison with some reference lines. Aspect is a little off so the graphic slopes up on the brown car but the length is off.
I think these are directly applied off a backer so they cannot be stretched unless the backer is, and its a waxed paper, so not likely.
These are pictures of both of my cars. You can see the switch in the right tail light on the orange car. The brown car the stripe looks like a school child cut them out. The orange car is correct.
Please remember these cars were massed produced and stripes were printed in the day using compasses not computers to make originals. You can buy many different OEM stripes and they are slightly different from one another. When you purchase an OEM stripe that is old please remember the color has faded in the box unless it has been kept in an Air conditioned enviornment. In addition, longitudanal stripes can be very challenging and should be applied carefully. These stripes were put on by the manufacturer in less than hour when they were produced so many cars will have different body lines where the stripes were applied.
We use OEM stripes and artwork to produce our kits.
We are a small family business that has a passion for assisting people with restoring their old treasured cars to original appearance. We receive many Thanks from people for even making stripes and decals with proper vinyl for these old vehicles, CAST AUTOMOTIVE GRADE 2 ML VINYL and silk screened.
Established in 1985
I believe I bought the stripes on the orange car from Dantes . That was a very long time ago, At least ten years. So where ever he would have got them from
The brown car was in the last 3 years. . I would have to look back to see where they came from. I believe I bought them with a project but I should have the tube they came in. The texture of the tape and the side stripes were nice. The taillight panel stripe was terrible.
Established in 1985
Are you trying to say the OEM cut these stripes out by hand? Not the way they were made. They needed hundreds per day! They were die-cut, and unless the OEM had a bunch of dies made by a troop of monkeys, they were all identical. If you happen to find OEM stripes 50 years later, of course they will vary due to storage conditions and possible vinyl composition variations.
