JefftheComputerMan
I have a 64 Valiant with a 318 (purchased from ebay little know about the setup). Pretty mild cam, and have no idea on water pump that is on it. It seems to pop a new leak on the cooling system every day! mostly on tlhe radiator, it looks to be the slant 6 original.
Should I go with a 2 or 3 core aluminum for a replacement?
The thermostat seems to open at 180 and stays cool until I sit at a red light, then it can climb up to 220 pretty quick (5 min or so). I live in Texas and it's currently in the mid 50's - 60's most of the time.
What the hell is going to happen when it hits 100 degrees outside?
I upped the radiator cap to 18 lbs from 13 lbs. Did I screw up? Is the water pump pushing too much?
I'm afraid if I replace the radiator I will have blown hoses or worse? Am I crazy to be afraid of the pressure generated here?
What is the "average" or normal pressure on a cooling system?:newb:
