DustYa318
Member
Hey guys, Im running a 650cfm holley on my sb 318. I am having a problem with initial take off. I have perfect response and power above 2000rpm. anything lower than that and she dies for a sec then comes up slowly. I have checked for vacumm leaks and have not found any. I have just over 6lbs of fuel pressure. The carb is a dual feed single pumper. My timing is set to about 24btdc Any advice. Thanks in advance.
