Holley 3310
pettybludart
Ontario,Canada
I have a holley 750 v.s .I,m going to change the plate in back with the conversion kit so i can jet up,also change p.v from 3.5 to 5.5.Does anyone have experience with this setup.I,m running a stroked 340(372)X heads pt and pol. xe284h cam,rpm air-gap,MSD 6al,headders,4 speed,with a 4.10gear,26.5x10x15 slicks.Any help would be appreciated before i get into it.Thanks
Easy enough to do.If it's the kit from Holley,they will list which jet size to put in the plate.I think mine ended up being a #80.The chrome line will not work with the new set-up...unless you already have a separate flexible line.Pretty straight forward,enjoy the tuning capabilities!Bob
