Jayramseyy
New Member
First, I'm sorry if I've posted this in the wrong place. Now, down to business:
My engine revs fine and is excellently responsive in neutral, but anytime I step on the throttle on the road it bogs down before taking off. I've read everything that Holley has to say about the problem and have tried larger and smaller discharge nozzles (their recommendation), as well as having made sure my accelerator pump is set correctly, with no change. So far there has always been one more thing to try in order to rectify the problem, but now I'm at a loss. Also, it seems like if I don't continue to press the throttle a little further when it starts to bog, then the engine RPM will continue to increase with negligible acceleration. Just not sure where to go from here, and I figured it was time to use a lifeline and ask the good folks at FABO. I appreciate any suggestions and apologise for any typos as I wrote this up on my phone.
I have a '78 318LA with TTi Shorties, off-brand HEI-style distributor, and a Holley 4160-1850c carb.
