Badart
Senior Member
Engine is a 318 Comp XE256 cam, magnum heads, hooker comp headers, magnum dual plane intake and a holley 4160 600 carb. It is a fresh engine and I have finally got the timing and carb pretty close. My problem is when I go to tap the throttle (to bark the tires a little) the car dies as soon as I let off. The car will idle all day at 700 rpm in gear and does not stumble at all reving it or standing on it while driving. It actually pulls hard to 5000 for a 318. My squirters look like they are coming on as soon as I touch the throttle. Are my squirters too much or coming on too early? I am not sure what jets are in the primaries, but it seems really close. Thanks Fabo.
