Holley 450cfm on Mild Slant six
Slantsix64
SSG
What up slanters! I was wondering why I always see everyone recommend a Holley 390cfm or a 500 cfm edelbrock. What about a Holley 450 Cfm four barrel?
I got a 225 punched out .060, ported oversized valves, 9:1 compression. .479 lift Howard’s camshaft. Custom duals into a y pipe. With a 4 speed B&T 3.09 first.
Got a 500 cfm edelbrock, but I really like Holley’s. Is there a reason the 450cfm gets no love?
Because it's a turd of a carburetor based on a 4150 with no secondary accelerator pump. It's primarily designed for "all show" street rod tunnel ram use. I think there's a 465 vacuum secondary that would work pretty well. @RustyRatRod is using a 600 or 650 CFM (I think Quick Fuel) DP on his slant, yours would probably do well with one, too.
The only 450 Holley offers is a mechanical secondary tunnel ram carburetor and they're not designed to run as a single. I have the Quick Fuel 450 on Vixen and it runs fantastic. I couldn't ask for a better running carburetor.
@RustyRatRod how was that carb right out the box? Jet size etc. I like how it has the adjustable secondaries pod on it.
I have used edelbrock for years, but since I learned how to tune a Holley carb there is no equivalent.
It was close everywhere, except the idle mixture. I had to play around with different IFRs and idle bleeds until I got it right. Took a little while, but it was well worth it. Nothing, but nothing will be right out of the box for a slant 6 except maybe a stock one barrel or two barrel. ...and that's especially true for a non stock slant 6. So if you don't want to tune, build a stock motor. lol
Lol imma tune regardless! Maybe I’ll just save up for the quick fuel 450.
I tried Quick Fuel's version of the 650 DP on Vixen not too long ago. It actually ran great but the low speed operation was too rich and I didn't spend as much time on it as I did the 450. The 450 ran so good I put it back on. It's just flawless. The 650 was too......everywhere but idle and "a hair" above.
