[SOLD] Holley 650 Spread Bore 4bbl Carb Mopar GM
66340SEDAN
FABO Member #3649
Minnesota
For sale is a used Holley four barrel spread bore carb. I never ran this or had it apart so I have no clue to its condition....so it will need a rebuild or great for parts. Everything moves and it looks to be in good shape. I think this was a replacement carb for the Mopar Thermoquad carbs? Not sure of the CFM rating on this but there is a picture with the carb numbers. $40 shipped to your USA door, sold as is. I am in central MN, thanks FABO :glasses7:
Holley 650 CFM 7002 Spread Bore QuadraJet GM Replacement 4175 Rebuilt Universal is where my search found Keith 8)
Yes. It will bolt right on a Thermoquad intake. Some people might think it has missing parts on the choke side, but it is complete. It is a divorced choke carburetor designed to work with a choke well in the intake. Those work real good. I have the double pumper version of that same carburetor. I just need to build it one of these days. GLWS.
EDIT: It IS missing the choke pull off, but those are CHEAP and plentiful. Chances are if it was there, it would be rotted anyway.
Thanks for the info guys :glasses7:
