Holley DP jetting
Marcelo Dart BR
São Paulo - Brasil
I have a Holley 4777 650 double pumper in my 318. I'm running a Mopar .528 solid cam, Performer RPM intake, headers and ported 318 heads. Compression ratio is 9.8/1. The distributor is stock with lighter springs and no vacuum advance, set at 13 initial.
The gas we have here is actually 80% gasoline and 20% ethanol. The carb came with 67-73 stock jetting and 6.5 power valve. The motor was misfiring at 3500 rpm with the primaries open and then at 6000 with the secondaries.
I swapped the jets to 69-75, but now the throttle response is not that good. I have some PVs here too, 4.5 and 3.5 I think.
I would appreciate any sugestion here.
Thanks
Well, no replies yet but I'm posting some updates.
I've changes the jets to 68 on the primaries and the PV for the 4.5. The throttle response isn't good yet... I have to open the throttle slowly...
