rymanrph
I installed my Sniper system last summer and I've been having some erratic issues. When driving the car coming off throttle, the car can either stumble or completely die. It doesn't happen all the time - sometimes it doesn't happen at all, but one time specifically I had to keep my foot on the gas to keep it from dying. It's rather annoying having to restart your car and traffic lights.
I sent a couple data logs to Holley and he concluded that I had EMI/RFI because of the negative timing in the data logs. On the log, the time doesn't start at 0, it starts at like -80 seconds and works its way forward.
Anyway, I'm trying to figure out how to eliminate these issues. Holley recommended moving my coil further away from the Sniper unit (it's mounted on the back of the intake currently) and also moving the MSD ignition box wiring away from the Sniper wiring. This is rather difficult since part of the Sniper wiring actually connects to the MSD box.
I read a couple articles that mention spark plug wires could cause a problem as well. I have 8mm Taylor wires that are only 4 years old. When I run the car in the dark, the coil wire glows anywhere it touches anything and I can see a slight flicker/glow at each of the spark plugs. Should this concern me or is that normal? I'm trying to decide if I should replace my wires or not. Holley recommended 8.5mm wires, but I don't want to pony up for new wires if what I have isn't the issue.
