Holley Z style street dominator for small block
hemichuck
Louisville Kentucky
I have a Holley Street Dominator intake which is the Z style(because it was designed by Zora Arkus Duntov) which has the devided plenum and the pulse tube in the back.Good shape, just needs to be cleaned up a little. I'll take $100 plus actual shipping costs.
It has 318 ports. These were made so you could bolt a 4 barrel on a 318 without having the negative effects of having the bigger 340 manifolds bolted on the small heads.They worked pretty good up to about 5000 rpm. They were pretty much an aluminum upgraded copy of a 273 HiPo manifold.
A little FYI, "Z" style refers to the passage in the rear that connects #5 and #7 to help negate the firing pulses on those two cylinders. Courtesy of Zora Arkus Duntov hisself.....or so I have heard. lol Supposed to be a real good piece. Not only all that, but Chuck is a stand up guy to work with. Ask me how I know. :)
I bought the exact same intake from fishy68 and love it.Btw he said the same on the design.I love it!!!
