Homemade Valve Spring Compressor.
Bodyperson
here over there
Tired of screwing around.
When you compress the spring, what keeps the valve from going with it? (I'm guessing it's to be used on a head still installed on the motor)
I made mine to use with the heads off, for solid roller springs.
Rope or air. I usued rope for the number one cylinder on this short block build.
I hope the tool clears the intake.
I made an adapter for putting air in the cylinder, out of a gutted spark plug. Only problem, I tried it on my tired old 283 in my 55....... and the air turned the motor over, and pushed the piston to the bottom of the cylinder.
I read that post. Did a ton of research. Can't know how the pressure is any different at TDC than BDC. I think RRR was alluding to that.
