Honeydew List Valiant - Ratty Build
1972_Plymouth_Valiant
Illinois
So a few years ago I bought this heap of a Valiant from a shady dealer in Vermont. It is a 1972 Valiant in Honey Dew with a black vinyl top and black interior. It is an Automatic Transmission Package car that was purchased new in Bridgeport, CT by Helen Hiostakis who I understand was a city councilwoman. The car has lived a rough life and looks like it was recently a beach car a it was filled with sand.
So first thing is to get it running. The transport driver was not happy, the dealer promised a running, driving car, and he wanted me to pay for a new battery, and acted like it was my fault. The car showed up missing the gas cap and the air cleaner lid, which I never got back.
Luckily I had some laying around to take care of it.
So I swapped a couple of rotten tires and drove the car to work and back after putting in a new gas tank. It drives like a heap, it doesn’t go, it doesn’t stop and barely runs. Time to change that.
I like it. Factory air too. Looks like rust free.Hard to find these days.
Be good to her.
Unseen. No wonder you called it a heap. Goes to show that photos hide allot.
Still tho, It has potential. Plus it has black interior and it's not green paint.
So the car had a rats nest of unsafe wiring for a cheap radio. I ended up ripping that out and finding a nice AM/FM unit that I will send out for a rebuild. Everything on the dash works even the seat belt minder.
After a couple drives and changing out the lights on the cluster, the engine had an oil light come on. This is a peanut plug head 225 out of a 77 Volaré. I will be doing something fresh for power.
I got a hood pad from DMT and got that on. I will be pulling the engine out in the next post.
In the mean time I ordered an E70-14 white line tire, and installed it on a powder coated 14”x5.5” wheel and a new trunk mat went in. I borrowed spare tire hardware from a Dart and I got everything cleaned up. I will need to fix a hole in the trunk gutter. But this is looking good.
I made my own package tray insulation and then dyed the brown package tray black. Sadly that was the only color close enough to work, for one with speaker holes and a defogger hole. I also painted the defogger bezel flat black.
The original heater side of the climate control was damaged beyond repair so I converted a heater only box to work with the air conditioning unit and installed fresh seals and gaskets everywhere. I am pleased with how it turned out.
Getting the 8 3/4” rear end housing in shape to be installed. It was acid dipped then painted with 2k high build primer and sanded. The differential will be a 489 with a 3.23 Sure-Grip.
Boy, you have been at it, that is for sure!!
The k-member was removed, acid dipped, painted and all the parts were restored or replaced. I upgraded to Kelsey Hayes disc brakes while I had it apart.
I picked up a set of cheap (free) roller tires from an old trailer and mounted them on the powder coated wheels.
It’s a little out of order but the old, tired slant six from the Volaré is out. Just so happens I found a slant six coming out of a Duster. Turned out it is a 1987 slant six block that has 30 lbs shaved off of the older versions.
Jumping back to present day, I got the bolts for the Kelsey Hayes calipers in and I repaired the damaged spindles. Then I got my E70-14 white line tires in. Outwardly this is supposed to be granny’s tired old Valiant but it is a hot Duster underneath.
