CLAY72dart
Is this the engine bay light I’m redoing all of the wiring in the car due to a lot of past electrical problems. There was a lot of loose wiring and wires not connected.
72 dart custom I could be completely wrong but I was able to buy a hood light on rock auto with the same connector but I could be off.Have never seen a stock underhood light on an A body.
What the heck are you working on?
Same it had a bulb but it was blown. I might put a light under the hood with a switch so I can get rid of that problem.I use a flashlight when I’m broke down at night.
do you know if the front plate has a light it could be that.I use a flashlight when I’m broke down at night.
It was definitely the side marker light connection I’m dumb.Have never seen a stock underhood light on an A body.
Edit it’s a blinker switch I thinkIt was definitely the side marker light connection I’m dumb.
I have it it’s just a little hard to piece it together.Go to www.mymopar.com and download a 1972 Factory service manual.
IIRC '72 is the last year for electrical diagrams that don't need some assembly to use.
IIRC '72 also has some cable routing.
The advantage of the factory diagram is:
a) The circuit, wire gage and full color code are listed.
For example, Q3-12BK* will be switched accessory, 12 gage Black with tracer.
b) The connector shapes and wire positions are drawn as they look (or close).
c)They are usually more accurate and detailed than aftermarket diagrams like the one above.
I wonder if anyone has labeled a whole harness before.I have it it’s just a little hard to piece it together.
It runs along the inner fender and terminates to a connector that gets plugged into the motor on the bottom of the windshield washer fluid reservoir. The reservoir is mounted to the the top of the DS inner fender.Does anyone know where this goes? I know
How it connects to the fire wall but where does it go to after that?
I don't know what you are looking at that is hard to piece together.I have it it’s just a little hard to piece it together.
Yes.I wonder if anyone has labeled a whole harness before.
www.forabodiesonly.com
