Hood Scoop Placement
fredmo1947
USA
Does anyone have the specs/measurements for mounting dual hood scoops on a 70 Duster. Are there any landmarks on the underside of the hood I should be looking for? I understand a drawing of the hole pattern may be out there...if so I'd like to see it.
Thanks
see if the pre drilled holes are there..
arrow points to the windshield.
Thanks for the info.....using the pictures previously posted....and the sharp eyeball of a friend we got it lined out pretty good. This is a 1970 hood so no pre drilled holes in the bracing. That made it a bit more challenging. Made up some cardboard templates which worked very well. Currently the hood is being prepped for paint....I'll post a picture when finished.
Thanks again
