hood scoop studs
WHEW! Got a link for that gold part?
I'd take a close look at them and run down to the hardware store. You never know what you may find. If not just simply a stud that runs through the hood and finished with a washer/lock washer, nut/locking nylon nut combo.
Actually, did just pick up a couple from Ace Hardware that will work, although they are not Mopar correct. I don't know what they were called, but if you have one to take with you and match up.......
Figures they would be cheaper for a reason.
Are there aftermarket scoops and bezels of decent quality?
6pk2goDemon,
Do you remember what they called the stud that you picked up at ACE?
I need some as well. I found a listing in the year one catalog for $5.70 each.
Craig
